Startup
Startup
Hello again :)
I got another question for you guys (and girls. :wink: )
How do you startup youre home made pocketbikes with maxi engine?
nobody of you have a kickstarter :?
Please tell me the secret and i will post my project in Bikes van leden :D
Its quit simple just start it like you start youre maxi ... a non kickstart one... some ppl use a drilling machine on the nut of the flying wheel and simply lift te leaver up
now go and post that bike ;)
They put the drilling machine og the flywheel? nice idea :)
I'll go put it up now :D
John_W
Bericht door John_W »
Rixen,
please be carefull. I start my bike with a drillingmachine (battery screwdriver), but made I kind of freewheel construction to be sure that the engine is not able to drive the drillingmachine. The first time I tried to start without freewheel, the flywheel nut came off when the engine started. An engine running at 2000 rpm in front of your face with a loose flywheel is not funny.
daans
Bericht door daans »
I push the minibike till it starts... Not a easy job with the high compression but it still worked everytime.
Daniel
But how do you start it while running? its a kickstart moped i can't see it :?
Jeroen
Bericht door Jeroen »
I think Daans didn't read your first post, were you say that you have a kickstart moped.
OOOOh i get it... you have not sayd you have a kickstart mini.
I know that Bouke has also a kickstart bike. maybe he knows the answer.
Groeten,
Jeroen.
[url]http://www.minibike.nl[/url]
Jopie
Bericht door Jopie »
You can start it by running and pulling al little lever on the handlebars.
This is the way it works on an original Puch with no kickstarter.
