Pagina 4 van 12
Geplaatst: do 06 apr 2006, 22:53
door rossi-nr.1
hehe
i use that blue electric pump
he pumps 15 litres per minute/él bombea 15 litros por minuto
I save 20 mm because I do not have that grey cog wheel on the crankshaft./Ahorro 20 milÃÂÂmetros porque no tengo esa rueda gris del diente en el cigüeñal
I have bought this pump for 25euro by a friend.
but in the netherlands u can buy them at
www.kampeerwinkel.nl
a peak pear shop has this type pumps, however,
sending a pump like this to spain should be more expensive than finding one there.
bye
Geplaatst: do 06 apr 2006, 23:00
door doraimontv
But with the pump electricity, you must take one bateria, no? that is not incomodo?
changing of subject...
that development to use you?
I talk about to the teeth of the pinion and the star.
Geplaatst: vr 07 apr 2006, 09:11
doraimontv schreef:But with the pump electricity, you must take one bateria, no? that is not incomodo?
Yes the pomp go's on electricity
Mensen ... volgens mij is word er bedoeld bij Changing of supject "wat voor een ontwikkelingen jij gebruikt en of je iets hebt met de tandjes op de krukas , en iets ? spietje ? of zo iets en een sterk => tandwiel ?
Ik kan het ook fout hebben natuurlijk
Sorry that im wrightig in Dutch but i need to translate
Geplaatst: vr 07 apr 2006, 14:51
door doraimontv
and he is not ugly to have to be with the pump electricity?
And not found out to me anything.
Geplaatst: vr 07 apr 2006, 22:38
door rossi-nr.1
a 24Volt (Voltage) battery doesn't weight too much...
and ugly?? u main a battery?? i hide it under my seat
Geplaatst: za 08 apr 2006, 08:48
Hey ,
Those wires and a pump and all those things look cool all to gether
Geplaatst: za 08 apr 2006, 15:15
door doraimontv
I already have almost all the curved tubes.
This week I want to make the chassis.
It will update with photos.
A greeting.
Geplaatst: za 08 apr 2006, 18:33
door puchrider
That is a very nice bike, Keep up doing the good work
Geplaatst: zo 09 apr 2006, 01:53
door doraimontv
Thank you very much Puchrider.
I hope not to make it bad.
Geplaatst: wo 12 apr 2006, 00:02
door doraimontv
Update
Geplaatst: wo 12 apr 2006, 10:58
door Scalibur
it looks very good !! Keep up the good work !
Geplaatst: wo 12 apr 2006, 14:41
door doede46
damn that looks good!
nice picture at the background..
keep up the good work!
MvG DoeDe
Geplaatst: wo 12 apr 2006, 15:28
door stevie-tai chi
Jaja de nederlandse bikes hangen aan de muur in spanje.
Geplaatst: vr 14 apr 2006, 02:10
door doraimontv
up
Geplaatst: vr 14 apr 2006, 10:56
Hey gasten :
Volgens mij heeft hij een probleem met zijn blok :
In order to align the pinion with the star, I must put the block alongside very displaced.
I believe that I must make all the chassis new, modifying the back rim, so that the star is but outside.
Not if I explain myself well.
That to think you.
Hij zegt :
Om de pignon op de ster te richten moet ik het blok naar de zijkant verplaatsen .
En :
Ik geloof dat ik het chassis moet nieuw maken, wijzigt de achterrand, zodat de ster maar buiten is.
*dit is allenmaal een beetje vertaald , aan de foto is ook te zien dat zijn blok schreef hangt !
Ik denk dat het niet uitkomt met de tandwielen , hij kan ze denk ik niet in lijn krijgen en hij wil tips ..
Zie foto :
@doraimontv
I will send a PB to *HANK* and Untiej i hope that those guy's can help you beacause thay have a pia bike to ...
