Pagina 7 van 12
Geplaatst: di 25 apr 2006, 11:50
door doraimontv
I cannot continue, until it does not know like solving the problem that I raise above.
Your aid needs to me.
A greeting and thank you very much.
Geplaatst: di 25 apr 2006, 13:27
door doraimontv
If, if and unemployed person(people).
Not as(like) solves the problem that I have.
I need your help.
Geplaatst: di 25 apr 2006, 15:38
door de winter
I don't understand what youre problem is..
Sombody know..?
Geplaatst: di 25 apr 2006, 21:40
door D_shooter
you need to put the front toothwheel and back toothwheel in straigth line
do you understand?
pic=
Geplaatst: di 25 apr 2006, 21:42
door doraimontv
He(She) reads mas behind.
The block is very fat. When I centre the block and the back wheel, the chassis remains very fat,
In order that the chassis stays mas thin, I have to displease the block to the left side.
Geplaatst: di 25 apr 2006, 21:45
door de winter
Ooow zn blok is zodanig breed, dat het blok erg naar buiten hangt, als hij het voor en achtertandwiel in een lijn zet, en hij meot heel zijn sub-frame verbouwen denkk dan..
Er moet een asje met 2 tandwielen tussen zodat het wel gaat...
Up here is not fore you, but I understand the problem, I think
Geplaatst: di 25 apr 2006, 21:47
door doraimontv
Only I can translate Englishman.
Excuse.
Geplaatst: di 25 apr 2006, 22:33
door steurtje
Look at my project!
My block is fett!
and my chassis is also fett!
maar wat De Winter zij kan ook.. ja.. mja kan ik allemaal nie vertalen!
Geplaatst: wo 26 apr 2006, 00:10
door doraimontv
But they all still have the block centred on the chassis and to my, remain displeased to the left side.
Geplaatst: wo 26 apr 2006, 00:19
door PIR3lly
I dont'get it...
Why is your block so much to the right???
Why can't you place it centered (so more to the left)????
What's the problem???
I can't imagine the front small gear is in line with the rear big gear, when the block is place like on the photo you're showing.
Geplaatst: wo 26 apr 2006, 00:38
door doraimontv
Geplaatst: wo 26 apr 2006, 11:01
The 190 / 200mm is correct,
And then, when you will centre your engine, it will be hanging a little bit to the right ! that is correct.. BUT that is GOOD !, Everyone has it.
When your front and back sprocket are in the same line, then it is correct.
The engine is not in the centre, but that is oke !.
Geplaatst: wo 26 apr 2006, 11:27
door Xigh
de winter schreef:Ooow zn blok is zodanig breed, dat het blok erg naar buiten hangt, als hij het voor en achtertandwiel in een lijn zet, en hij meot heel zijn sub-frame verbouwen denkk dan..
Translation: Ooow his engine is so wide that the engine hangs out of the side of the frame a lot when he wants to line up the front and back sprocket. He has to modify his sub-frame I think.
Geplaatst: wo 26 apr 2006, 12:00
door doraimontv
Xigh, Thank you very much for the translation.
Untiej Mini Racing, But to it(he,she) me moves very much to the right.
It(He,She) stays very badly.
I have to invent something in order that it(he,she) does not put so to the right.
Geplaatst: wo 26 apr 2006, 12:08
door Xigh
When looking at the photo you placed a few posts up I don't see that much problems. You could center it a little more, but not that much.
It looks like your frame is pretty wide, but you could also place your sprocket to the outside a little more. You could ask Rossi nr1
