merk staat er niet op
dit zijn de specs die id handleiding staan
http://i30.photobucket.com/albums/c319/ ... C00755.jpgEngine
*2-stroke
*49cc
*air-cooled
*2.5KW at 8700 Rpm
*dell'orto carburatore
*fuel admision reed valve direct to krankcase
*ignition : electronic
*spark plug NGK B9 ES
*Starting hand pull typemanual
*clutch centrifugal, friction
Frame
*welded High stress steel tubes
brakes
*frontwheel disc brake
*rear wheel disc brake
wheels
*front of light alloy 6.5''-63
*rear of light alloy
tires
*front size 90/65 -6.5''
*rear 110/50-6.5'' 90/65-6.5''
fuel
* petrol octane 92+syntetic oil
*mixing ratio 25:1
*tank capacity 2 litre
unloaded weigth 19 kg
carrying capacity 110kg
basic dimensions
*lenght 950mm
*width 500
*height 565
http://i30.photobucket.com/albums/c319/ ... C00756.jpg
http://i30.photobucket.com/albums/c319/ ... C00757.jpg
http://i30.photobucket.com/albums/c319/ ... C00758.jpg
http://i30.photobucket.com/albums/c319/ ... C00759.jpg
