What kind of welder have you guys used, for welding your frame?
A electro welder, or co2, can both be used? Which one is the best?
Electro or Co2 ?
- John_W
Michael,
basicly is doesn't matter which type of welding you plan to use. The strenhgt of a correct welded frame is for each type of welding the same (when you are the expert). I did all my welding based on CO2 with a nice result (to my opinion
But be carefull with CO2. You can create very nice looking bad welds which have no strength. Please try a little bit on restmaterial of the same size that you plan to use.
succes with your project
