I have a problem with my valve(ventil), in the rear naaf. The valve isn't long enough to stick out the side, because of the width of the rear naaf. Compared to the front naaf, the wideness isn't that long, and the valve can stick out. Even if the valve WAS long enough, and could stick out, it would hit the tandwiel? What have you guys done..?
