I saw this picture, and noticed that the ignition looked 100% like the same that piaggio 50cc scooters use? And I wondered, is it the same that can be used on a maxi ?
Italkit innerrotor
Italkit innerrotor
Hi forum..
hey..thats correct, there are too hpi (horse power ignition) for maxi's it gives you a quick aqcelleration on your mini.these are the same as the one that they use in the scooter races, but than for a maxi engine. so a scooter hpi dousn't fit on your maxi engine. Gr Dave
- John_W
Michael,
basicly most of the scooter ignitions can be used on the Puch. You need a right turning innerrotor and most of the scooters do haven them. For example I used the HPI unit of Minarelli Horizontal with a modified mountingplate. But not every innerrotor ingnitions does have a variable timing based on the rpm, so please be aware of that.
