Rixen,
to improve acceleration of the minibike I tried to adjust the rpm where the clutch stops slipping to a higher level. Therefor a reduced the weight of te clutch segment by removing some material. I don't have any photograph of the clutch, so i prepared an image.
This clutch has segments made out of 3 sheets of steel. When you are cutting away the triangular form, the clutch will fall apart in 3 pieces. So you have to weld these 3 parts to eachother. The two holes are drilled an can be used for final adjustment.
There are also clutch segments made of aluminium which make this modification more easy. With the aluminium clutchsegements you have to use the springs of the steel clutch because they are more stiff.
hopefully this explanation will clarify your confusions
